RSLinx Classic EtherNet/IP Driver Adapters
aiki202
Aug 2007
Pennsylvania
178
How does RSLinx Classic EtherNet/IP Driver "Windows Default" adapter relate to the all of the available Windows adapters?
Is there a way to correlate the "Windows Default" selection to a specific adapter?
Can or does this default adapter change based on available adapters (like if using a VM, or if disabling an adapter, etc.)?
None of the RA literature even mentions this selection (at least everything I have read thru). Most folks I have asked over the years simply don't use this selection as it's an unknown.
Interesting... so the target adapter CAN change based on various conditions of the computer.
This was my main question... is the Windows Default adapter for the EtherNet/IP Driver always pointed at the hardwired (RJ45) NIC if it was available or could it change.
Thanks!
I personally never set it to use the default adapter.
Since connecting every time usually requires changing the IP address to match the PLC subnet I always select the device I am connected to, whether that be the hard wired adapter or WiFi adapter. This also avoids it hooking up to the TeamViewer and VPN virtual adapters.
It certainly can. In my experience it doesn't do so by itself, something else needs to happen or be modified for it to change.
But agree you should set it. Else it will change on the first day of your vacation.
Good morning, Guys: We want to add one PF525 EENET to our existing Rslogix 5000 system,in the Rslinx classic we can't see Ethernet tree,we have...
3,806
Under the "Ethernet devices" driver from RSLinx, I see all my remote devices when my laptop's wifi is enabled. Under the Ethernet/IP driver, I...
4,881
Hello, Any help! My Rslinx classic with version 3.8, Ethernet /IP Driver cannot detect anything within the network, but using the ethernet...
6,765
I have seen on my co-workers laptop that he is able to connect to multiple PLCs using his EtherNet port going into a PLC then thur the backplane...
1,605
Good Evening, I just received a new laptop and need some assistance. My old setup worked well. So same cables, Ethernet Switch etc. Only thing...
2,564
