vidp
Hello all,
Some time ago we replaced a client's old Rockwell SCADA with Omron's SCADA. It was our first and so far only time working with Omron or Rockwell.
We used RSLinx Classic lite and 1747-UIC USB to DH485 adapter and then Kepware as an OPC server for Omron's SCADA.
The PLC's used are Allen Bradley SLC 5/03. In RsLinx Classic Lite I configured the driver as "DH485 UIC devices", selected the correct COM port and RSWho found the available nodes.
It worked fine for about 9 months then suddenly nodes couldn't be found anymore and the communication to the SCADA went dead. First I thought it might be the adapter cable so I replaced it but it didn't work. I tried installing a newer version of RSLinx but no luck. Then I came across something that said that deleting harmony files might help in situations like this. That didn't help either.
In the meantime the client has plugged in the computer containing the old SCADA which still works fine so the PLC's must be working fine.
I've run out of ideas what else to try.
If any of you have any experiences with similar problems I would greatly appreciate any advice.
Kind regards
Vid
Kind regards
Vid
