RSLINX Communication
Dragosvr6
Oct 2014
Montreal
Hello guys,
As you can see I am new to this forum. I have a problem that I can not find anywhere on the internet.
RSLINX Classic 3.71
RSLOGIX 500 9.0.5
VMWare Windows 7 Ultimate 4 cores and 4 GB RAM
I am trying to communicate with the Automation network that we have in the company, via ETHERNET. I configure my Ethernet/ IP driver, I can see all the nodes that are browsed, it refreshes. Everything works perfect this far. The real problem is when I open a 5/05 project in rslogix 500 in this case, and I try to go online with the processor, I get different errors from Rslogix 500. I get these errors: processor not responding OR Corrupted processor or unknown processor OR Upload Failed! Communication Errors!. Three different types of errors. I even configured an ethernet device driver, i see the target processor but I get the same errors. I want to mention also, that when I connect physically on the processor, it works. When I ping the processor that I want to connect to, I don't loose any packets. I tried to delete the harmony files, it still does not work, I tried to use the repair button from control panel to repair rslinx still a no. I have no idea what else can be. I am desperate to understand why I cant connect, when I m plugged to the network and I can see all the nodes, in rslinx.
I want to mention that we have two other laptops, my colleagues. When I connect from their laptop with the same exact file, or when I upload from the processor directly, everything works fine. I compared their rslinx with mine to see if there are any differences, but there aren't any.
Sorry for my english, and thank you for your help. I hope you guys understand my problem.
What I would do:
compare on all three laptops:
1. running processes
2. software versions
3. ethernet settings
4. run CCleaner (I use the free one) https://www.piriform.com/ccleaner/download
5. ask your AB supplier about the issue
Are you running virtual XP? I still use XP, but my niche is legacy. I have several laptops going back to DOS6.22; WIN95; WIN98; W2K; XP with REAL serial ports... more reliable to me than VIRTUAL.... BUT... just ask Rockwell or AB if you haven't already. I have not had great results so far on W7 and Rockwell.
I don't think that the SLC 5/05 supports EthernetIP. Try using the standard ethernet driver instead.
I think that Andybr has it nailed ...
set up the Ethernet Devices driver ... you'll have to know (or discover) the IP address of the SLC-5/05 ... and you'll have to type that IP address into the Ethernet Devices driver ...
I know that this is going to sound crazy - but the letters "IP" in the Ethernet/IP terminology/name do not stand for the same thing as the letters "IP" when we talk about Internet Protocol ... (please don't shoot the messenger) ...
here in (too small) a nutshell is the problem you're facing ... the Ethernet/IP driver will automatically browse the network and automatically find devices that are Ethernet/IP "compliant" (that's the good news) ... the tricky part is that some (usually older) devices might indeed have an IP address - but yet (I know it's crazy) those older devices might not be Ethernet/IP compliant ...
let us know how this works out for you ... it's a common problem ...
if you have a TechConnect contract, take a look at Knowledgebase Article 45952 ... basically in short simple terms it tells you that the most reliable Ethernet driver to use for all Allen-Bradley devices is the UN-automatic Ethernet Devices driver ...
Hey! In my previous queries on how to handle an OPC server like RSLinx in the ArchestrA IDE galaxy, I have succeeded and the answer was to just...
1,834
Hey guys, I'm messing around in my rslinx classic program trying to get familiar with the Porgram, under the Driver Diagnostic General tab I...
1,182
Dear All, I have just experience running RSLinx Ver. 2.59 to connect with ControlLogix 5000 1756-L73 with Firmware rev. 24.11, found: the RSLinx...
1,820
Hi everyone, I have a customer that is using wireless modem to communicate to many different PLC's and HMI's. I just added my PLC and HMI to...
3,884
Good day, Does anyone know if the device shortcuts can be backed up, if they are stored in a SQL-Database?
2,024
