RSLinx enterprise and kepserver.
Mar 2012
witbank
Hi There
I experienced a problem on the factory talk view se scada where we are running RSLinx Enterprise for a data server for the logix processor famely on ethernet protocol, now we want to employ another data server that is kepserverV5 for modbusTCP/IP protocols on the Factory talk view se.When i create the drivers and tags they wont work on a distrubuted system bet it does work on a standalone system.Can anyone help that maybe experieced the same, maybe a driver that i need or something.
Thanks Ferdie
I think Kepserver V4.6 and Factory view V5.1 and above is the requirement
did you ever get this working? i am having a similar issue right now and i am running factorytalk 8.1 and kepserver enterprise 5.13.235. it will work when i run a test on my computer but when i put the app on the panelview itself it wont work.
We did.
Check the HMI firmware
Also confirm the ip addresses or interconnection settings.
Kepware has its own I/O monitoring functions
Start them up and see if it gives you a green tick.
Also check your modbus connection setting
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,447
Besides a $3,000 license to purchase a RsLinx Gateway License for every remote computer network that I work on. Is there another way to get to a...
2,700
Hi, I'm running FTView v9 on a VM machine. Host win 10 64 bit, virtual win 7 pro. I've come to configure communication on this project (1st...
2,170
Good day, Does anyone know if the device shortcuts can be backed up, if they are stored in a SQL-Database?
2,021
Hi, I am trying to read data values from CAT generator via monico(redlion) module to be displayed on factory talk view studio via RSlinx...
4,765
