FTView RSLinx Enterprise Issue...
Rob.Hill
Dec 2009
Yorkshire
47
I'm running FTView v9 on a VM machine. Host win 10 64 bit, virtual win 7 pro.
I've come to configure communication on this project (1st time using this particular laptop) and after I click communication setup - RS Linx eneterprise just hangs and it doesn't allow me to specify the PLC path. Sometimes it gets itself out, others I have to exit all FTView.
Things I've tried so far:
1. Running the FactoryTalk Directory configuration wizard for both network & local.
2. Re-installed RS Linx enterprise.
3. Deleted the private directory for the application.
4. Make sure the ethernet is connected on the VM machine (simply nat'd it to the host wifi)
Any further ideas?
Rob
Thanks for the suggestion.
I can ping google from the virtual machine. I'm not online with the PLC so obviously can't ping that, but wouldnt expect that to effect the configuration within FTView.
I've turned the firewall off
I'm trying to setup a connection on my FTView Studio ME software that is accessing a PVPlus panel on an Ethernet Subnet accessed across the...
4,454
FactoryTalk View 7.00.00 The SE Stand-Alone application won't run, error message pops up saying "You do not have security privileges to access...
3,606
Title says it all. I got this laptop as a hand-me-down. It had Factory Talk View Studio and I was able to run the application and open .apa and...
2,045
I have a project using FTView 5.1, I can connect tag in controllogx by RSlinx OPC Server, but cannot communicate by RSlinx Enterprise(it can find...
3,765
Hey Friends. I am currently trying to write approximately 700 tags from FtView13 to an Logix Emulate 5000. I am using rslinx DDE/OPC to create an...
396
