RSLinx preventing computer standby
geoplc
Oct 2006
PAinesville OH
123
Is there a "fix" or work around for the issue of RSLinx preventing a computer from going into standby (i.e. when the lid on my laptop is closed) I cannot seem to find any info on this issue but it becomes a battery killer when "helpers" leave RSLinx running in the background. I am running RSLinx Classic 2.51.00.21 on a XP SP3 computer (Although I have had this issue on 2000, XP SP2, etc.)
You could try not running it as a service.
Start - Programs - Rockwell Software - RSLinx - RSLinx Launch Control Panel. Stop it if it's running, then uncheck "Run as a service". Then you can start it again.
Not positive it will fix it, but it's something to try.
I have this problem as well, it seems to be the PIC driver that keeps it from going into standby, I generally delete the driver since I don't use it very often.
The other option is to not run it as a service as dmroeder said and close it when you don't need it.
I do not run it as a service, the only driver configured is ETH-1 which is most of our equipment. I just have never had a laptop with Windows that would allow standby if RSLinx is running and was wondering if I was missing something.
Did a little more investigating and found that the DH+ driver is usually left running as it is the second most used driver after our ethernet. This was the problem. Which leaves me off where I started, if I cannot get them to shutdown RSLinx and don't think they will delete the DH+ driver. Thanks for the input and insights.
Sometimes auto start of the drivers can cause problems What I do is set them to not auto start & only start them when I want them although this means stoping them on shut down this is a problem when you are using many different plc software programs that might use the ports.
RSLinx seems to be preventing windows from shutting down or logging off. Anybody know the fix?
4,271
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
59
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
84
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
234
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
279
