Hmmm. A HUB, rather than a switch, and a public IP address rather than a private IP address. Red flags galore.
What else is connected to the hub? At what IP addresses and masks?
Keep in mind that a hub or unmanaged switch can only service one domain at a time: if you have some devices at 198.213.62.xx and others at, say, 192.168.1.xx your behavior will be crazy intermittent. All those devices need to be in the same domain: all in 192.168.1.xx, for example (assuming the mask is 255.255.255.0). And there is NEVER a reason to have a mask any wider that 255.255.255.0 in a control network.
Pardon me while I hop on my soapbox now
And I hope nobody is planning on leaving a hub, much less a cheapo Linksys device, in a control network. Hubs are bad news in a control network: they promiscuously broadcast everything to every device. And if any one Ethernet device is running at 10K bits, the whole network slows to a 10k rate. Egad. Especially when a good industrial 5 port 10/100 switch can be had for less than $100...
Ken's observation that you are using a public IP address is troublesome. If this is ever in any way connected to the Internet, you have a potential for a strange bug. Always use addresses in the private IP ranges: 192.168.xx.xx, 10.xx.xx.xx, 172.16.xx.xx thru 172.31.xx.xx
OK, done with the soapbox.
