RSLinx Slow to Open
eight_bools
Apr 2019
Oklahoma
72
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an eternity. In reality it may only be a minute or two.
I have never had an activation, and am using the free version. Is there any way to skip this check at startup?
This was an issue that I think I first noticed in Windows 7. I haven't seen it in quite some time, but here is what I did to resolve it. My directions are for Windows 10 so if you are using another version of Windows it may be slightly different.
  1. Go to Microsoft Edge
  2. Click the three dots in the top right
  3. Select More Tools then Internet Options
  4. Click Advanced
  5. Scroll down to the Security settings
  6. Deselect "Check for publisher's certificate revocation"
  7. Deselect "Check for server certificate revocation"
  8. Click OK
  9. Restart the PC
If your computer is older and has Internet Explorer the first couple steps would be slightly different. With Windows 10 you could also just search for "Internet Options".
OG
  4. Click Advanced
  8. Click OK
  9. Restart the PC
OG
That seems to have helped a bit, I am running Windows Server 2016, found them in the advanced menu in Internet options.
I was working on some bench mark tests for different drivers and once I got to RSLinx I am getting a really slow read time. It is taking over 2...
4,351
We are experiencing random slow performance when writing to a string tag in a Clx PLC via ethernet and RSLinx 2.43. The write is most of the time...
5,431
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
67
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
95
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
238
