Slow DDE Writes to ControlLogix via RSLinx
DaveW
Apr 2005
SoCal
389
We are experiencing random slow performance when writing to a string tag in a Clx PLC via ethernet and RSLinx 2.43. The write is most of the time fast (100ms or less) but after 5 writes or so, it would take more than a second to do the write. Basically, we are writing a "0" to the string which the PLC has set to some value containing 15 characters. This is a Wonderware Intouch application using RSLinx DDE to talk to the Clx. Is there a way to get more reliable and consistence writes to the PLC?
Thanks for any help.
Get rid of DDE if you can, and use suitelink. It's a lot faster and more stable. You need to set up an OPC link. Then in Wonderware, under the configure topics tab, you would put something like this;
Node Name 169.265.109.91 (CLX ethernet address)
Application Name Linx
One of our Wonderware apps where I work is still using DDE. P.O.S...slow and unreliable. Another day, another project.
For a possible short term fix, maximize your paging file size for virtual memory. DDE is asynchronous so alot of things can slow it down (antivirus programs, etc) Also, a perdiodic scan with a registry cleaner can help too. I've been using Registry Mechanic with good results.
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
158
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
92
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
75
Hi. Importing a 2014 aapck in 2023: no problem using it, adding windows, works very well, no problem whatsoever. Creating a new project: as...
755
I am having a weird experience using KepwareEx6 as an OPC Server for a set of SLC processors where the tag data is not updating remotely at the...
577
