SLC5 Slow Updates in Kepware
Gforce3864
Aug 2023
Aiken SC
I am having a weird experience using KepwareEx6 as an OPC Server for a set of SLC processors where the tag data is not updating remotely at the correct rate.
I have a KepwareEx6 server configured with 46 channels one SLC PLC per channel and roughly 160 tags per PLC configured in Kepware. The SLCs are connected to the network via DH+ I have two data highway devices with 23 devices each split between their two channels (12 per channel).
The tags have varying scan rates to try an optimize tags I need more often vs ones I don’t. The general scan rate I’ve used is 1000ms per tag on these devices. What I’m seeing though in most cases is that I won’t see a tag change in Kepware OPC Quick client for far far longer sometimes it takes 10-50s to see the tag change when I know the tag is changing every second.
If I’m monitoring the SLC's tag changes using RSlinx I can see it changing in nearly real time. I even have a custom logging service I use that makes use of an INGEAR driver and it doesn’t have any delays in tag scans on the SLC processors.
Has anyone had an issue like this before?
So...DH+ is a token passing protocol, each CPU only communicates when it has the token, and it's serial communication. So...depending on HMIs, historians, messages, etc... I doubt 1000msec updates is doable with 13 devices per network.
Why would RSLinx be able to read the tags at a low ms scan time whenever I use it to check? It has to go through the same route to the processor through the DH+ that Kepware is using.
I have a issue with one PLC that takes much time to response to excel through DDE and on FactoryTalk Site Edition Local. I have already tried...
2,132
The system has 4 SLC5/05s L553 series C and 8 PV+ HMIs and 1 Versa View Box. There is Fiber and a Hirschmann MICE on the LAN. With all this on the...
2,546
Programming and saving a program while online is very slow, up to 20 minutes to save a program while online. I'm using a compaq nc8430, xp pro...
2,531
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,558
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,273
