RsLogix 500 1746-HSCE ???
Adam303
Aug 2009
Chicago
587
:geek:Hi to All. 1746-hsce High speed counter. Does any one have any links or a project that uses the counter in a .rss file besides AB manuals that can explain the adressing of the High speed counter. Ab manuals are a little bit confusing me. project scope is to acoumillate a total value of gallons used over a 24 hour period of time using a pulse generating turbine as a input.
Thanks !!:geek:
Ok I see that this issue had been brought up meny times before in meny diffrent trends, and i guess the best way to do this is to read the ab manual utill i get it.
From my understending to access the parameters in hsc i/o i have to write it in the logic and copy to the hsc. So i think. but what does the first pass or whean does the first pass XIC incruction acually become true?????
G'day lads, We are using an Allen Bradley PLC slc5/03 with an analog input module 1746 ni4. we have a sensor with a response rate of 250ms. in...
3,138
:banghead:Hi To All. I'm Having trouble using the HSC Instruction. whan i try to enter HSC pop up box appers "HSC Instruction not supported by the...
6,689
I've got a slc 5/03 and the 1746-FIO4V card= 2 Input (V or mA) and 2 output (0-10 vdc) and am setting up an analog output in RSLogix. If so, I...
9,623
I am having trouble getting an output from a no4i module using a 5/03 processor. I am writing an integer value into the panelview 600 at n:11.0...
3,634
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
92
