RSlogix 500 ML1400 code problem
bearsgone
Jun 2010
chico
49
Hello
I have three pumps that run on 3 timers one after another non stop.
All three pumps share the same current sense which is what I use to determine the status of the pump(run).
The logic attached works fine with contractors. Fail over works correctly.
As soon as I switch to current sense, when a pump is called and somebody turns a switch to off position, next pump in line should pick it up as a fail over. For some reason when a fail over occurs, instead of switching over to the next pump, it starts flickering, trying to run both pumps. I am positive it has to do with the fact that i am sharing the same current sense (three wires going through it) but can not figure out what is causing this up and and down flickering. Please help!
Hi! I made an addition to an existing program. There are already configured communication between the PLC (ML1400) and the HMI (PV+ 600)...
2,880
Hi! I'm currently learning the AB programming softwares (RSLogix 500 and FTView Studio) However, tomorrow I'm going to make a minor adjustment...
3,603
Pulling registers from Modbus devices and have to swap words before CPW'ing them into floats. Right now, for instance, I'll COP N7:17 to N7:48...
3,757
Hello I have two blowers that alternate every day at midnight. Additionally I have contractors that tell me if pump 1 fails, start pump 2. However...
3,307
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
96
