rslogix 500 multipoint and custom data monitor
david90
Apr 2010
ca
202
Which one do you use and when? It seems like multipoint can only monitor 1-bit memory location while custom data monitor can monitor both 1-bit and multi-bit memory locations. I wonder why AB has two types of data monitor file in rslogix 500.
Often in troubleshooting, only a 1-bit output is of concern, but in other cases you want to monitor an entire word, or 16-bit value such as an analog output. Different types of monitor are used for different purposes. One size or type does not always fit every purpose.
I use the CDM which can be customized with different radix.
I also use the CGMs a lot (RSLogix500 Professional) to mix and match and provide sort of a crude HMI right there on top of the ladder for monitoring things.
I have not used the Multi-point monitor at all, but after some reading, it looks pretty interesting:
RSLogix500 Help said:
The offline multipoint list is stored in the project file. It is not part of the processor image. The online multipoint list is stored in the processor’s memory and is, therefore, cleared whenever the processor’s memory is cleared.
When using the MicroLogix controller descriptions are always stored in the .RSS file. With the SLC 5/04 and SLC 5/05 controllers the descriptions are stored in the processor.
I may have to search the knowbase on this...to see if it has advantages over the CDM.
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
92
182
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
89
Will someone please convert this logic to pdf?
133
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
163
