RSLogix 5000 Aliasing?
Old No. 7
Jun 2010
Ohio
173
There has to be an easier way to do this.
For a lot of our "standard" equipment programs we alias all the digital and analog I/O. This works great until you want to do some testing and don't have all the I/O cards - which we rarely do.
So the current method is to...go to the Program Tags, find the tags with Aliases, click, click, click, delete, rinse, repeat, remove the modules in the I/O configuration, verify project and pray that you didn't miss any aliases since RS5000 will automatically change all the data types from BOOL to DINT for some reason, find the errors (for things like t/c modules where we look at the module status bits), fix, re-verify, re-fix. And just like that you're off and running. What a giant PITA.
With Micrologix there is a nice little "Ignore Configuration Error" box that you can check. Please tell me there is a easier way to do this than what I describe above.
Thanks. Not sure how I missed that.
I guess I'll have to save my Rockwell rant for another topic now. At least there are plenty of topics to choose from.
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
95
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
201
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
645
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
581
