Rslogix 5000 and magellis hmi
LWoll
Feb 2013
neepawa,manitoba
Hi guys
i am new to rslogix 5000 programming, tags etc... I have used rs logix 500 for a number of years and have set up some projects with micrologix and used magellis hmi.. Works fine.
However i seem to be running into some issues with rslogix 5000 using a compactlogix l33er and want to communicate to a magellis hmigto5310 hmi.. The problem i am having is addressing on the tags in the vijeo designer software which is used to program the hmi... It asks for the data tables, but in rslogix 5000 i only gave the tags a name,chose data type and created a tag...
Has anyone tried this before using an ab controller and a schneider hmi?? I am being told by local schneider sales that they see alot of it done because schneider makes a superior hmi... Any ideas ?
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
582
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
518
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
124
