RSLogix 5000 AOI
MATT116
Dec 2009
Dallas, TX
330
I just installed RSLogix 5000 V18.00.00 (CPR 9 SR 2.
When I try to add a AOI the only type I can select is Ladder Diagram. In other words the function block or structured text option isn't there. Did I miss something in the install?
When I go to about RSLogix 5000 and select more info I see this.
Installed Components:
Ladder Diagram
Motion
Trending
External Routines
Should I see something about Add On Instructions here?
Thanks in advance
Dang I see I have the standard version. I did not know that it was an option as I did not do the ordering and this is my first time to use 5000.
Anyway thanks for the info Mickey.
Hi All, I'm working on an AOI that needs a ONS incorporated into the logic. Every time I run the instruction the ONS gets stuck on even when the...
3,234
Hello!! I am trying to create a AOI to perform lead lag pumping operations based on run time. I do have 8 pumps out of which 6 are duty and 2...
2,664
Hello, Have aoi written in Ladder to pass in and out string variables. String VAriables that interact with PLC program are declared as InOut...
4,300
I am currently working on integrating Vin Verfication into a PLC via calculating and verifying the check digit. Is there an AOI for this or is the...
1,585
I am trying to create an add-on instruction to round a value. I have defined the following parameters for the instruction INPUT: ValueToRound...
16,883
