RSLogix 5000 App Crash
Joshua37
Aug 2014
Dallas
47
Hey,
I am facing this annoying problem with Rslogix 5000. The app crashes whenever I am trying to open or access the controller/program tags. o_O
What is more confusing is the fact that not every 5000 project on my computer seems to have this issue.
I have tried restarting the system couple of times but no luck.
I have couple of screenshots attached of the error.
May be someone knows about this and will help me out :)
Will re-installing the software all over again fix problems like these ??
I don't want to do so, but if I may not have other options,then fine.
Please assist.
I don't think I have an answer for you, but that looks like windows7
what version is the PLC program you are trying to modify ?
WIN 7 won't work on older versions. ( I don't know how well it works on newer versions either )
And it often doesn't give you an accurate indication of what's the problem
Well, the version was initially my suspect as I was having trouble with v16, but then I had the same issue with a different program which was of v19. A program in v17 works just fine. So I don't think its a version menace.
I can't find anything regarding this online, not even in Knowledge base.
BTW, I was able to find a tech note about a similar app crash in Factory Talk View.
135020 - FactoryTalk View Studio ME/SE crash on Startup
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/135020
I tried these steps but in vain. And yes I reckon you are right, it is a Windows problem.
I have never been able to "fix" RSLogix application crashes without doing a full uninstall and reinstall...
That seems to be the case here as well. I actually wanted to try all hands on deck before giving in.
I'll do the re installation chore and get back with this problem if still exists.
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
579
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
518
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
124
