rslogix 5000 counters set in HMI
italo2008
Feb 2009
Padova
95
Hi
I'm not skilled in RSlogix 5000..
I need to set the preset value of a counter in HMI. How can I do it? It seems that I can only write a numeric value directly in ladder logic, but I need to make the operator able to modify this value...
thanks.
Virtually all HMI software packages have the ability to address sub-elements of standard ControlLogix tag types.
Every Counter tag includes three DINT elements; a Flags word, a Preset (.PRE) value, and an Accumulated (.ACC) value.
The syntax would be "MyCounterTag.PRE" in a numeric input field.
What HMI product are you using ?
Hi I'm not skilled in RSlogix 5000.. I need to set the preset value of a counter in HMI. How can I do it? It seems that I can only write a...
3,506
66
183
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
620
