The best answer I can come up with is:
- Open controller tags
- Sort by data type
- Select the first TIMER and press Ctrl+E
- Run your eye over the list for duplicate TON/TOF/RTO's and press Ctrl+Tab to return to controller tags
- Select the next timer and repeat
Not as simple as you're looking for I'm sure. But you'd probably do 10 a minute so as long as there weren't hundreds of them it wouldn't take too long
just make sure as well as controller scoped tags, you check the program scoped tags as well.
