RSLogix 5000: During unused system overhead Time Slice
Zaheer
Apr 2010
Germany
Can anyone explain me what this option means?
In manual, 1756-pm005_-en-p, I read
"With RSLogix 5000 software, version 16, you can configure any unused portion of the system overhead timeslice to:
• Run the continuous task, which results in faster execution of application code and increases the variability of the
program scan.
• Process communication, which results in more predictable and deterministic scan time for the continuous task. (This
is for development and testing of an application to simulate communication.)"
I did not understand the second option. As it sounds I can select the second option when I am simulating my programs (lets say on Softlogix) to reserve some time for communications. But if I am on real PLC with all the communications, what it means if I select this option?
It means that you will be hogging system time slice for simulating nonexistent data transfer.
This option comes handy at development time when the user tests logic execution without being able to establish the communications environment the application will eventually run within. The developer should be able to get an idea of the Continuous Task execution timing when the application will become functional within a "live system".
Obviously, when done testing, the option should be "un-checked" and the system should regain all of its resources.
Thanks for the answer. I never understood this option before. Yesterday I read the manual I mentioned above and did not believe at first. I had one project in "live system" where this second option was checked, how stupid I thought....
thanks.
It happens...Forgetting is very human...;)
What matters is finding the mistake and promptly correcting it.
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
578
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
518
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
123
