RSLogix 5000, Emulate & RSView Studio
crazylizz
Sep 2007
S'Western Ontario
Hey guys,
I am currently using RSLogix 5000, RSLogix Emulate 5000, and RSViewStudio ME, and I have few questions.
My goal:
Be able to sync the HMI display "Test Application" with the PLC Program via the emulator.
What I have accomplished so far:
The ability to read all my tags from the emulator (and thus the PLC program) with no problem. I can update the PLC program while in Remote/Run mode, and it will update my tags inside my Test Application -i.e. I change a Boolean Tag value from 0 to 1, and the indicator will change in the Test Application.
This tells me that I have no problems communicating PLC->HMI.
Now part of purpose of the screen is to be able to cycle a arrays via a counter in the PLC program. I am unable as of yet to perform this task -i.e. push a button on the HMI, and have the counter change in the PLC program. Which would mean I am having problems communicating HMI->PLC correct?
What sort of simple things am I overlooking here?
I've tried the search button, but nobody has seemed to ask this (or if they have I haven't found the proper answer yet)
I cannot thank everybody enough for the help that you have given me in the past, and hopefully now as well.
I will more than likely have additional questions to this as well in the future.
-crazy
crazylizz said:
Hey guys,
My goal:
-crazy
I had the same issue about a year ago
This post details how I resolved it
Ian
Ian,
Thank you VERY VERY much.
I did a little bit more troubleshooting on top of that...
Just a little oversight I had made in combination with this, I sorta forgot to switch to run mode. *doh* Hope it was just a noob mistake.
I'm fresh meat right outta school, so it wasn't looking too good on my end here at work when I couldn't perform.
Thanks once again, this definately help me get back in the good books ;)
Joe
Respected Members I try to install RSlogix Emulate Version 20.04.00 but the error occurs during the installation which is shown in the image...
977
I have RSLogix Emulate 5000 v21. How upgrate it to v31?
1,123
I want to to communicate a panelview plus with an RSLogix emulate 5000 and I know that this is not possible by RSLinx Enterprise, how can I do it...
2,757
I have an existing Compac Logix program and I would like to run it using the RSlogix 5000 Emulator. is it Possible can some bocy give me directions?
2,276
We’re looking to setup a stand-alone training station with FT View and a connection to a simulated plant system which would match the RSLOGIX 5000...
3,783
