RSLogix 5000 "expand all" tags
Dec 2008
PA
16
If I have an array of 1000 or more elements using a UDT ( maybe 4 REALs and 4 INTs or 4 DINTs) for each element. When I want to place values into the tags or check for the correct values, I can open each individually. But that is a lot of work.
When I Expand All "tag_xyz" Members, it also expands all the elements of the DINT's or INT's. I suppose because "all members and their children will be displayed" or "For Integer tags, the composing bits (BOOL) will be displayed".
I would rather not see all of the bits within a DINT or INT.
Is there a way to avoid this expanding of the bits within a DINT or INT?
No there isn't, or you would have found it already...
It is what it is...
Perhaps you should complain via tech support, perhap[s a "feature request"...
62
170
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
613
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
549
