RsLogix 5000 Hex to SINT array
Omnicode
Jun 2009
Knoxville
Hello i have been trying to figure out a good way to take hex and convert it to an array of SINT[].
Here is what my failed attempt looks
b4a30fc735fc7341cec4635b3e712bce
like.
There are two issues with what you have shown:
1)Your 16-bit number is far too large. Logix is 32-bit, and while there is some support for 64-bit LINT it definitely won't be able to handle the number you have shown.
2)The COP instruction cannot handle constants/literals.
Break your number up into smaller chunks and use BTDs instead.
EDIT: This assumes what you actually care about is the bit pattern of your hex number, not necessarily the value itself.
And if you already have a constant hex value, why not just put it in the sint array manually instead of entering the hex constant into your instruction?
You could COP the data into the SINT .DATA array member of a string data type, then you would see those hex data as the string it is meant to be i.e.
$VL25,2,960,0*TT
$VL25,2,960,0*TT
You are an true gem. I was basically taking long ascii commands and having to manually break them down into hex nibbles and put them in an array.
Lead by the comment about the string.data i found i can now just paste the commands i a string makin sure to use $$ to get my symbol and now I ca roll the commands directly into my WriteSocket.Buf[].
Thank you all for the help.
I am trying to concatenate 3 hex numbers into 1, and I am doing this as follows: 3 registers with 8 bit values in them need to be joined into 1...
3,675
How can I convert a SINT Hex number to a string in RSLogix 5000.
9,401
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
581
