yasamanvakili
Hi
I want to create a typical AI(Analog Input), because of that I should pull out for example the Local:x:I.ChyData for every channel(it will use for IN value on SCL to convert it to Engineering value). I have 74 analog input.
Is there any way that I can creat a loop to get the specific information (Raw value, fault status,..) from AI Card.
I'm programming with RSLogix 5000.
Thank you very much
Yasaman
Thank you very much
Yasaman
