RSLogix 5000 Indirect Addressing
woodward_uk
Mar 2006
Hinckley, Leicester
42
Hi there
I'm currently converting an RSLogix500 program that I wrote 20 years ago into RSLogix5000 for an SLC to CompactLogix upgrade.
The program uses indirect addressing, I have figured out how to address the required words within an array. For example my original N16:[N44:15] is now N16[Pointer2], where Pointer2 is an INT that contains the value of the array word I wish to reference.
The problem comes when I try to reference the same word position in different arrays. The original software used N[N9:40]:6 to point to word 6 in different data files, but I can't find a way of achieving this in Logix5000.
I've searched the forum without success, any help would be gratefully received.
Thanks.
http://www.plctalk.net/qanda/whereisit.shtml?cx=010759363700548729232%3Asbguabkbras&cof=FORID%3A10%3BNB%3A1&ie=UTF-8&q=two+dimensional+arrays+rslogix&sa=Search
Try to find some documentation of how to create and use two-dimensional arrays.
You could also create a UDT that comprises the elements of a 1D array, and then create an array of those UDTs, and access them like this: udt[N9_40_pointer].row_array[6]
You could also create a 1D array and have it emulate a 2D array. E.g. say you wanted to emulate a 10x10 2D array:
  • Create a 1D 100-element array
  • 1D elements [0..9] correspond to elements [0,0..9] in the emulated 2D array
  • 1D elements [10..19] correspond to element [1,0..9] in the emulated 2D array
  • 1D elements [90..99] correspond to element [9,0..9] in the emulated 2D array
  • So to access emulated 2D element [ROW,COLUMN], you access 1D element [(10*ROW)+COLUMN] in the 1D array.
    • So the emulated element at row 3 (of rows 0..9) column 4 (of columns 0..9) in the emulated 2D array corresponds to indirect address 34.
It's basically bookkeeping. I think RSLogix 5000 allows some arithmetic in the brackets, e.g. maybe twod_array[row10+column] where row10 = row * 10, but probably not twod_array[row*10 + column].
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
675
I’m working with indirect addressing and trying to make an HMI where each Rectangle Object has a tag of “A[0-127]” with a correlating Push Button...
4,221
Hello, I'm trying to create IO tags that will allow I/O to be changed via the HMI once the system is deployed, and without needing to connect via...
2,802
I need some help with Indirect Addressing where I used the conversion tool to convert an RSLogix-5 program to an RSLogix-5000 program.
31
7,943
25
