RSlogix 5000 instalation problem
lllerena
Jun 2002
Lima - Peru
21
I am trying to instal the software RSlogx 5000 pro on a PC:
IBM Netvista, Pentium 4 ,Windows XP Profesional, (spanish), but i get the folowing error :
La instruccion en "0x66133ad3" hace referencia a la memoria en "0x00e3043b". La memoria no se puede "read". wich translated would be:
the Instruction "0x66133ad3" makes reference to memory on "0x00e3043b". The memory can not be "read".
this message is made by "Msiexec.exe"
and then the instalation stop. I haver installed that software before on other machines, but do not get that problem. I do not want to reinstall an english "Windows XP", since I have everything configured.
Anyone that can help me?
besides that, I also have a PC that work fine with Rslogix 5000, but can not see the SFC routines. In there a problem of instalation, version, or key?
thanks in advance,
Luis Llerena A.
That sounds like a default windows memory error, not something with the activation of the software.
If the CD is clean and not scratched, I would guess that one of the files on the CD is corrupted, in which case you would need rockwell to send you a replacement.
I think it was some incompatability issue between older version of RSL5K and Windows 200/XP.
I remeber v7 was first official version with Win2K support.
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
578
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
518
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
121
