RSLogix 5000 Motion Control Instruction
EKSwaim
Feb 2006
Greensboro, NC
17
I am trying to figure out the MCCM moves. There are three types; Circle, Via, and Radius. I do not understand the Radius type. I am confused on the value for the radius itself. The example in the Instruction Set reference manual gives a graph of radius 15 and -15. My question is relative to what? I know the values are supposed to be the radius value and a radius starts from the center of a circle to the edge. So where is the center in this example?
Thanks.
Consider the geometry of the radius in that example. A line that exists through the 2 defined points is a chord through the circle(s) and the centerline will be R distance away from those 2 points along a line that is perpendicular to the chord through its midpoint. In other words, given 2 points, only one, two or zero circles of radius R will exist that intersect those 2 points. Assuming the distance between the two points is less than to 2*R, than you choose which of those 2 circles that exist to use by specifying the Radius as either positive or negative. If the distance between the points is 2*R, than only one circle will exist and its center will be the midpoint of the chord.
Thus, specifing the midpoint is not required. It can be calculated knowing the location of the two points and the radius size. There will never be more than two circles that can exist and contain both points.
Hope that helps.
Yes, that helps. Thanks. I think I would prefer to use the 3 point method. The curve of the arc is not as important im my application as is the objects I need to miss.
Hello everyone, Ho do I go about making changes to a "Motion Axis Parameter" e.g. PositionScalingNumerator that is currently grayed out in the...
1,405
Hi all, Can anyone give me a basic idea on how to use the motion instructions in rs logix 5000(including coordinate system)...can i run these...
2,050
Good day fellow PLC Programmers, I would like to ask for help especially to our Allen Bradley users. In my 5 years working with PLC, I have never...
5,974
Is it possible to view motion axes in motion with RSLogix5000? I have never used this software before, so I have some rookie questions regarding...
5,617
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
45
