RsLogix 5000 Scaling analog input to use in PID
Dera bsee
Sep 2012
Los Angeles
36
Hello all,
First I'd like to say thank you for viewing my post. I need to learn how to scale an analog input on the RSLogix 5000 without doing so on the Card configuration. I've read forums on here stating to use function blocks or the compute instruction. How will I be able to apply it on a pid instruction.?Lets say for example I have a 4-20 mA signal from a temperature transmitter. My scaled value would have to be from 0 to 180 degrees and I will be controlling a control valve for steam. I've seen different examples stating to get the Raw Input then rawMin, rawMax, sclMin, sclMax and to get the slope and so forth. I attached to files of examples that I have seen on here but still don't really know how would I use it for a pid loop and how to actually apply it. I know there's wise programmers on here and would appreciate your input. Thank you so much. :unsure:
analog card scaling using move ans compute instruction.jpg analog card scaling using move ans compute instruction 002.jpg
Hello all,
Hi Dera,
Morning.
Have you tried PlantPAx's AOI...????
I usually use a modified SCP AOI from the AB website.. Looks like the old SCP from the SLC RSlogix 500 instruction set.. Is the same calculation as you posted, just hidden away..
Also think you can actually scale the PV in the PID instruction, though haven't ever used the functionality myself
Hi, I am confuse with the scaling tab on the PID dialog box. On the Process variable I am using a tag that is already scale. 0 to 16 Feet Level...
2,479
I am new to programming, and I was asked if I could take the 0-10V signal from a load cell and scale it so we could see it on or HMI...
2,375
OK, the "Janitor" here with more dumb questions: I've got an Analog I/O point (AT-13) on a 1756-IF8 module which is configured as a 4-20 ma...
42
12,760
Good day everyone, I am a little confuse about the analog input of ab and its setup and configuration.. why do we need to config the hardware...
2,192
I need to scale analog input. I'm using software RSLogix 5000 and analog card 1769-IF4XOF2. So I want to make scaling for current sensor...
5,078
