Rslogix 5000 SCL online programming
Kansas Tech
Aug 2019
Kansas
Hello all,
I was trying to do some online programming on a AB control logix PLC v20. I added a new function block routine and added in an SCL instruction. I then tied the input pin to an analog input (the data type for this tag was INT). I then created a new tag (real data type) for my output and tied it to the output tag.
I then set the SCL instructions Max’s and Min’s and dropped the edits into the program. I could not get anything on the output of the SCL instruction, but I could see the input reference changing.
I then deleted what I had done and created two new tags (both real data type) and tied one to the input and the other to the output. I then dropped this edit into the program and manually changed my input tag value. This also did not give my scaled value on my output tag.
Am I missing something? Do I possibly need to download the project to the proc instead of online editing?
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
578
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
518
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
121
