RSLogix 5000 to 1398 fault
russrmartin
Aug 2002
Eastman, Wisconsin
744
Hey guys. We've got a drive that we're putting back in that comes up with a positive soft overtravel fault every time it's enabled. The soft overtravels are disabled in the Limits tab in the PLC and set to status only, yet it still causes an axis shutdown. Has anyone seen this before? The drive is a 1398 ddm 150. I guess I'm not understanding why the fault is acting like a shutdown fault when it is set to status only. Thanks.
Russ
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
49
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
166
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
603
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
539
