RSLogix 5000 to ML1000?
PLCRookie
Dec 2005
I'm right here...
305
Gentlemen,
Is it true that I cannot program a ML1000 with RSLogix 5000?
I was able to connect in RSLinx, and I can see the ML in RSWho in RSLogix, but I cannot go online or upload. I also could not stop the driver AB_DF1-1 in RSLinx. Had to shut down the laptop to be able to stop and delete the driver.
This is my firs attempt with the ML series, but I have been working with a Control Logix system.
Thanks in advance!o_O
They are two completely different platforms.
The good news is its no where near as much money.
There is a version of RSLogix500 which is specifically for the ML line - it could save you some money if you will never program a SLC500, but if you'll possibly do SLC500s then get the full package.
Thanks guys for the info. I just needed to do a little program change to a machine that we purchased recently from Italy. Nothing bigtime. I actually have access to a copy of Logix500, it will just be a little more time to get it done. We have AB, AD, Siemens, GE, and Omron here, so I have trouble sometimes remembering things........🍻
70
186
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
623
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
560
