RSLogix 5000 TON Timer Time Base
studentplc1
Feb 2010
Canada
29
Hey,
Can someone tell me what the default time base is for TON timers in RSLogix 5000? In the TON timer I don't see the option anywhere to edit it. I just see Timer, Preset, Accum. What is the time base?
As Brownhat said, it's 0.001 seconds. It is not selectable. Coming from a PLC-5 or SLC500 world, that may at first seem like a limitation until you realize it's 32 bit. That gives you:
over 2,000,000 seconds
over 35,000 minutes
over 596 hours
over 24 days
hello
please i want to make shift register in RSlogix 5000 but from where can i get clock to these flipflop register specially even the timer it self need trigger to operate
thanks
thanks (kannanmkm)
please is there any simple way to store data in RSlogix 5000 for example i have analogue input data to PLC and i want to save these data with time to copy these data for example to another program
If it were me I would use a UDT array with the time and data you want to store. Then use GSV instruction to get the time, and a simple MOV to write the analog data into the UDT. I can think of several ways to accomplish what you want to do, so just find a way that works for you. I'm sure the the folks here that really know what they are doing could come up with a hundred more ways of doing it, but this is what I would do. This link will help you with the GSV instruction for the time.
http://www.contactandcoil.com/autom...the-controllogix-system-time-in-ladder-logic/
Will.
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
548
How do i use the TON command to monitor the number of hours something stays on for? what would the preset value be in this case? Or is there...
4,508
Hi, So I have one push button(non-latch momentary) and would like use it to trigger two function sequences with the short press for primary...
2,000
How can I add the "Go To..." function to the RSLogix 5000's Standard Toolbar?
3,596
Got into a bit of a debate the other day, and wanted to get some gurus' opinion/expertise on the subject. When duration of an output's ON (or...
10,771
