Rslogix 5000
DBLD99
Oct 2003
USA
230
Hello everyone, I was wondering i need to use some system time in my program but I dont see anywhere where i can read the controller time I set in the properties window. Anyone have any ideas
thanks for your time
The answer to this type of question is not only brand specific, it is usually model specific as well. A good answer will depend on your providing this info. However, for many models the time is in S:40, S:41, and S:42.
In the Logix-family controllers, a lot of the things that were formerly in the "S" Status file in SLC/PLC are accessed using "Get System Variable" (GSV) instructions.
The WallClockTime object is a good example. You execute a GSV instruction and make the target an array of seven DINT values:
DateTime DINT[7] The Date and Time in human readable format as follows:
This: Contains the:
DINT[0] year
DINT[1] integer representation of the month (1 - 12)
DINT[2] integer representation of the day (1 - 31)
DINT[3] hour (0 - 23)
DINT[4] minute (0 - 59)
DINT[5] second (0 - 59)
DINT[6] microseconds (0 - 999,999)
Thanks guys for the input works good. Didnt know about the the get status instruction.
thanks again
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
93
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
196
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
641
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
575
