RSLogix 5000
tom pateson
Mar 2012
kendal
Hi
I am rather new to RS Logix 5000 can any one tell me if there is a way to view all your ladder logic in one screen. (Like a large map?)
It depends.
How big is your screen?
How many rungs of logic do you have?
You can trun off toolbars and only have the ladder screen open full and it will be over the controller organizer.
You can also turn zoom in and out on logic to get more on the screen
tom, you might be interested in the "Browse Logic" function which hides itself under the "Search" menu....
It gives you a searchable "tree-like" view of the logic, that you can expand interesting-looking branches, and explore the logic along them. (Interesting-looking, in this context, may require that the program has adequate rung comments.)
It only displays the "do", "action", or "output" type instructions for each rung, and that in itself is a great fault-finding tool. You can, from there, choose to go to the actual rung in the logic to see it all.
It's hard to describe the usefulness of it, but it's worth checking it out to see if it helps you.
I've had feedback from people who didn't know it existed, but now use it regularly.
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
82
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
190
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
635
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
564
