RSLogix 5000
I figured out the timer PCE errors for the acc. and pre. Any idea on the status bit conversion to gsv. Any help is appreciated. Thanks
Details ! The PLC-5 Status file is dozens of words long, and the GSV instruction has dozens of different objects it can access.
For example S:7/8 labeled as processor status rack 0 BT queue full. How would I convert that to a GSV. I don't understand the structure and terminology of that instruction.
That's a Status bit that doesn't have an equivalent in ControlLogix.
There isn't a built-in queue for MSG instructions (which are what provide the Block Transfer function in ControlLogix), so I would either not use the status bit at all, or provide an alternative method of detecting and displaying problems with the ControlNet data transfer to and from analog or specialty modules.
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
156
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
578
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
518
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
120
