RSLOGIX 5K V16 Errors
plcengineer
Jan 2004
USA
176
I loaded Logix Version 16 on my machine with RSLinx 2.51 and I continue to get the following error: rsvchost.exe error. Does anyone know how I can get rid of this error and what is it telling me?
Thanks,
P
From the Rockwell Automation Knowledgebase:
Navigating to a new graphic display produces wireframes for all animation links on the graphic. The screen is properly configured, and the tags do exist..Navigating to a new graphic display produces wireframes for all animation links on th
Question Navigating to a new graphic display produces wireframes for all animation links on the graphic. The screen is properly configured, and the tags do exist.
Answer Problem:
Navigating to a new graphic display produces wireframes for all animation links on the graphic. The screen is properly configured, and the tags do exist. Examination of the RSView Activity log shows the following error for each tag referenced on the graphic.
Tag <tag name> has not been activated
At the end of the tag list the following error is logged
Failed to maintain connection to name server, networking problems are prohibiting communications (result = 800706be)
Cause:
The Rockwell Application Services service has terminated unexpectedly. The process is RSVCHOST. For more information about this cause,
Jump to E16939591 When browsing the Factory Talk name space online to a ControlLogix processor, no data is returned for the expanded folder
Solution:
Launch View Studio and browse the Factory Talk name space. This will cause the RSVCHOST process to be relaunched, and the graphic should then appear correct with no wireframes. It is recommended that you reboot the Factory Talk server afer experiencing this problem to avoid other potential runtime errors.
Problem: Navigating to a new graphic display produces wireframes for all animation links on the graphic. The screen is properly configured, and the tags do exist.
Cause: The Rockwell Application Services service has terminated unexpectedly. The process is RSVCHOST.
Verify: RSVCHOST process is not in the process list in the Task Manager
Cure: Reboot
Prevention:
Catalog Number:
DocFullNum: P16940899
Revision:2.00.01
Fixed in Revision:
Package:
Modual:
DISCLAIMER
This knowledge base web site is intended to provide general technical information on a particular subject or subjects and is not an exhaustive treatment of such subjects. Accordingly, the information in this web site is not intended to constitute application, design, software or other professional engineering advice or services. Before making any decision or taking any action, which might affect your equipment, you should consult a qualified professional advisor.
ROCKWELL AUTOMATION DOES NOT WARRANT THE COMPLETENESS, TIMELINESS OR ACCURACY OF ANY OF THE DATA CONTAINED IN THIS WEB SITE AND MAY MAKE CHANGES THERETO AT ANY TIME IN ITS SOLE DISCRETION WITHOUT NOTICE. FURTHER, ALL INFORMATION CONVEYED HEREBY IS PROVIDED TO USERS "AS IS." IN NO EVENT SHALL ROCKWELL BE LIABLE FOR ANY DAMAGES OF ANY KIND INCLUDING DIRECT, INDIRECT, INCIDENTAL, CONSEQUENTIAL, LOSS PROFIT OR DAMAGE, EVEN IF ROCKWELL AUTOMATION HAVE BEEN ADVISED ON THE POSSIBILITY OF SUCH DAMAGES.
ROCKWELL AUTOMATION DISCLAIMS ALL WARRANTIES WHETHER EXPRESSED OR IMPLIED IN RESPECT OF THE INFORMATION (INCLUDING SOFTWARE) PROVIDED HEREBY, INCLUDING THE IMPLIED WARRANTIES OF FITNESS FOR A PARTICULAR PURPOSE, MERCHANTABILITY, AND NON-INFRINGEMENT. Note that certain jurisdictions do not countenance the exclusion of implied warranties; thus, this disclaimer may not apply to you.
[font=Helvetica,Arial,Geneva]Copyright © 2006 Rockwell Automation. All rights reserved.[/font]
I have a pc running windows 10 pro that is on a network that does not have internet access. I need to put RSLogix 5000 on this computer for a...
4,767
Anybody can help me. I already read document in software rslogix 5000 and I think i can use software rslogix 5000 calibrate for flex module...
1,748
I have never seen this, before. We have one particular machine running v16. If RSLogix 5000 is running in the grace period, it will not allow me...
11,614
Hello ladies & gents, Is there any way to print an RSLogix project tag database in a way that the printout specifies (example:) pressure xmtr...
1,747
I just installed version 20.01.01, but I did not see during the install how to install other firware support files. I need to be able to open a...
4,524
