I'm trying to connect a Beckhoff Controller to a Rockwell Controller (I'll get more specific in a little bit) so that the Beckhoff is the master. Beckhoff said they had a solution, but they said it would require connecting to the Rockwell Controller as a Generic Ethernet Module.
To test this out on my own, I have been trying to connect a 1756-L61 to a 1769-L30ER (just what we had around the office). The 1756-L61 is communicating through a 1756-EN2T. I'm using RSLogix 5000.
I attached a picture of the configuration that I used for the Generic Ethernet Modules. Both use the same configuration (besides the IP Address).
I get a Module Fault of (Code 16#0315) and in the help it basically says you get that error when the Electronic Key passed but wasn't an "Exact Match". It says it happens when the actual module is different than the module in the I/O configuration tree.
When I look in the Module Info tab of the Generic Ethernet Module, it actually does tell me what its trying to communicate with, but it says the Module Identity is "Mismatch"
Am I just trying to do something that isn't possible? Anyone out there get this to work before? Any help is greatly appreciated! Let me know if there was any vital information that I left out.
