RSLogix DH-485 Node changing
MUITECstudent
Oct 2006
Lancaster PA
Hello all:
Sean and I have almost completed our DH-485 project. A final question:
When you open a new MicroLogix 1000 PLC out of the box, it is set up for DF1 protocol. We know how to change it to DH-485 protocol using a handheld programmer. How do you change it using RSLogix? Basically, that is the final piece of the puzzle. We need to be able to plug the PLC into the PC, and switch it over to DH-485. Also, we need to be able to change the node value. How do you do this?
many thanks:
Teo & Sean
Millersville ITEC students.
In the RSLogix 500 Controller Organizer, there is an icon labelled "Communication Configuration".
Click on it and you'll get a dialog box that has fields for selecting the Primary Protocol (that the MicroLogix uses when it boots up) and setting the node number.
When you load your program into the MicroLogix, it will accept these changes. The software will even warn you that accepting those changes will disconnect you from your current communication method.
I'm trying to communicate on a dh485 network with about 10 nodes on it. I'm using a laptop with RSLogix and a pic. I can communicate with...
3,268
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
70
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
106
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
186
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
198
