RSLogix5000 edit history
jatui
Jul 2018
Westmeath
Hi all, I have a question on rslogix5000 code. An edit was made to a rung within a routine, this edit was running on test on and off as we needed it. At some point, someone had finalized the edit. My question is can I look back and find out what date or time the edit was finalized or when the code was last saved. I really wanted to know how long the edit was finalized. Thanks
if you have the .bac file, you can check it's date. As far as I remember, by default RSL5k saves 4 last backups.
It should be in the same folder where your .acd file is. When you modify somethig, it creates a file with name like "Originalfilename.BAKXXX.Windowsusername.acd"
BAKXXX is the number of the backup
You can also increase the number of Backups created in the Options.
I also have a Backup Directory that I move older Backups to so that I have an Audit Trail.
Stu....
Leaving edits in a processor, so that you can switch them on and off as you described, is never going to be a good idea, and presumably you now know the reason why. The other thing to consider is that having edits "on test" would have prevented the other person making edits himself, so he would have switched them to "Untest Edits". That may have been done at a wholly inappropriate moment, and the usual warnings about personnel and/or machine safety would definitely apply, as you don't get a confirmation box to come out of "Test Edits" mode.
You could, of course, use conditional JMPs and LBLs to "switch" code in and out, as needed, but I find a cleaner solution is to move the two rungs, or sections of code, to new subroutine files, and use conditional JSRs in the main code to decide which to execute.
hi DABA, Thanks for that i am only getting back to this issue today. the code is accessible to all and we just use the test to override an error when were waiting for spare parts. so we needed a spare sensor and to overcome the sensor alarm we would put test code in place but at some point the code was excepted and ment,
even with the new sensor replaced the error would never come on as it was permanently overridden, we just dont know how long its been like this. but your right bad practice is in place for this type of thing.
I am unable to start any online edits, attempting to double click does not work and attempting to right click and select edit rung, but edit run...
12,722
I'm new to RSLogix 5000, been using 5 & 500 for years, and have a question about online edits before I screw up the equipment. Doing an online...
8,882
Hi Everybody, I have been using RSlogix5000 for quite a while and did a few big projects. One thing is annoying me, when I right click a tag to...
2,966
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
