RSLogix_Options Question....
JoseM
Jul 2011
Texas
381
Question for you guys. Is it possible to set the "RSLogix" software under options to store the programs on an a centralize external "Network Access Storage (NAS)" unit.
Yes, if the external storage can be made to show with a drive letter and file address. You can set the program library directory in RSLogix 500 with "Tools, Options, System Preferences".
In that little window where you set the "Directory" when I go the "Drive" area and get the "Drop Down" window, it only shows A:\, C:\, or D:\
I mapped the NAS to drive letter Z:\ but it doesn't show as a drive.
You should be able to set Logix to read from a network drive by default. If you are in an office environment where your pc stays connected to the network 100% of the time it should work ok. If you are on a portable pc on the plant floor where you connect and disconnect a lot (sometimes unexpectedly), then I would recommend against it. Losing connection to the network drive with a PLC program file open causes some odd behavior like not being able to save the file. You can usually get around this by saving to a different filename but I prefer ro avoid it instead.
Since I work in a lot of different plants, I adapt to their standards. But if it's up to me, I do it this way.
Aquire the latest file on my pc. (from whatever source)
Go online, save file to asfound_20120913 folder on my pc.
Do your work.
Save the file to asleft_20120913 folder on my pc.
Save the file back to the network. (or where ever they keep them)
For some clients I email the "asleft" copy when I get back to the office.
IF you are talking about RSLogix500, and not RSLogix5000, then there is the option to set two save paths, a Primary, and a Secondary.
When you save a project it will attempt to save to both paths specified...
This feature does not exist in RSLogix5000.
Hi, Contractual issues on both sides are solved if there is any way to have a Read Only password for a Logix 500 PLC program for a MicroLogix...
2,309
Does your workstation customizations save to that project when other people open it?
1,984
I have a weird problem with Logix 5000. I'm running Win7 Ultimate 64bit and logix versions 15-20. I cannot modify the layout (move the location of...
9,224
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
95
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
127
