RSSQL writing to PLC5
pheel
Aug 2006
Montreal
Hi everyone,
I was wondering how can I write easily from a SQL using RSSQL to a PLC5 ? I just need to transfer 10-15 register from SQL to a N file.
Can RSSQL use RSLinx to write directly to the PLC or I need something else. I read the Rockwell documentation, but it is not clear enough.
pheel
RSSQL can do this. I would recommend that you consider FactorySQL from Inductive Automation for this task. It's designed to do this sort of thing quickly in a drag and drop fashon. You can download a free trial to get started and I have no problem helping you get it set up. If you have an OPC Server and SQL database installed the whole process will take under 5 minutes.
thanks for your reply,
FactorySQL seems very easy to use and less pricy than RSSQL. I'll take to my customer about it, he usually prefers Rockwell software because of the local support he can get.
pheel
Hi, I am currently in need of help with regarding of the ways on how to connect RSSQL to suitelink without using 3rd party driver...your reply is...
1,100
Hello all I am a student and also very new to PLC's and RSSQL. I have a situation where I am trying to link rslinx classic to ms sql through rssql...
2,296
I'm trying to get a string from the plc and store it in a database, but I can only get the first byte, I know there should be an easy solution to...
1,928
Hi Everybody, While I am trying to start configure RSSql,I m getting Error(33190)'The service could not validated using specified username and...
3,458
Hey all, I am trying to define data points in RSSql and am having some problems. I have a ControlLogix 5555 controller and an OPC topic set-up...
3,953
