RSTune Software for PID Loops
SCRUFF
Dec 2006
South Carolina
I have a PID loop controlling the stroke on a Soda Ash Dosing Pump to control pH on a water treatment plant. There is an extrememly long deadtime and I cannot successfully tune this PID loop. Not only that but I have trended the pH and it seems to drop out every now and then to basically nothing.
Thus, I was wondering if RSTune Software could assist in controlling this pH PID Loop as well as does anybody know the ~cost of this software and where I can get a copy of it?
THANKS!!!
PH is logorathmic.
PID alone will have a tough time.
If you can linearize your PH signal, that should make tuning MUCH easier.
I'm not sure if RSTune has the characterizer funtionality, but I know that RSLoopOptimizer does.
For a typical non-linear loop where PV/CV is not constant you would use an output characterizer based on test data points. However, for the pH loop, you would use an input characterizer.
I haven't done any pH loop tuning, but if you find the literature/user guide for the software, it will explain it all better than I can.
i want to activate rs tune ver 13 what i can do?
1,441
hi all, Now, I trying to find RStune and RSloop software from rockwell, but I haven't found it. so Where can I download RStune and RSloop ? thankful
6,170
Hi guys. How do I communicate to a PID using RSLinx? I'm using ControlLogix ladder. Tks a bunch for any ideas.
1,848
Hi guys. I'm new to this forum so please bear with me. I'm using a CompactLogix PLC and have a PID controlling a 30' conveyor, which is controlled...
2,058
Hey Guys, just looking for some opinions on RSTune... Has anyone used this software? and what did you think? Is it worth buying and how easy is...
5,703
