RSView 32 Tag Problems
peebs
Apr 2006
Nova Scotia
Hello, I am currently developing an upgraded HMI package. Converting wonderware to RSView, I am having a problem with the tag database. When I try to add a new tag, that points to a device whether it be a byte or an I/O address, I am not able to add the tag but if the tag is just a memory tag it will allow me to add the tag. the lic i have is for 5000 tags and i am currently only using 1500 tags. Any help would be greatly appreciated.
you need to create the node first for the i/o driver so you can select it when configuring the tag as an I/O, it's been some time now since I did it& I am assuming you are using lynx.
Peebs,
Are you opening the RSView Tag Database? If so, what happens when you click on "Edit, Insert Row"? Does a new blank row for a new tag then pop up? If not, you have a strange problem, if there are only 1500 tags in a 5000 tag version.
Would you by any chance be trying to type in a new tag on top of an old row? RSView will not let you do that. You must insert a new blank row, or go to the bottom of the tag database and use the blank last row for your new tag.
If there is no blank bottom row, then your database has more than the allowed 5000 limit. How can this be? Easy, the tags can be in hidden folders that do not show up unless you click the "+" on the folder in the tree menu on the left side of the main menu screen.
I would double-check your licensing (help/tag statistics) in case somehow it may have been corrupted or lost during an upgrade or software load. Memory tags do not count against the tag count so that sounds too much like a tag limit issue.
Hello Everyone. Let me start by being completely honest with everyone. I am trying to teach myself RSView so that I can program PanelView Plus' at...
5,589
Hi all, so I am trying to get the correct version of RSview 32 Works to make some edits to the tag databases in some old HMIs we have. I did a...
994
Hi, I have RSView studio v4.0 running on one virtual machine, and RSLogix 5000 set up and running on another virtual machine. These are tied to a...
2,341
Hi, first sorry my english. I need help. Im using RSView32 7.40 I want to write value to a tag from Visual Basic. i calcualted something in...
1,361
Hi everyone, there's a problem and hope you guys help me solve it. When I am trying to import tag file (.rsv) file into the .rsv project file...
1,399
