Rsview 32 works
stu
Aug 2005
England
786
Hi i have a question in tag database how can i change the address of each tag name eg, i have two projects which are the same but one is line 1 and the other is line 2 which is going to be put on a spare hmi screen( so if either line fails this screen can be fitted?) i have been told to change the address [tortilla_line_1] to [tortilla_line_2] on all the tags is there an easyer way. thanks stu
STU are the tags pointing to the same processors? WE have 3 systems that look identica. WE just point them to the correct processor.
We have a bunch of machines that are the same. We define the OPC server on each machine as ThisMachine and tags are [ThisMachine]PLCTagname. Then all that needs to be changed is which PLC the OPC server points to, which is done in RSLinx.
If you absolutely have to use Line_1 or Line_2 in your addressing then look into using Alias OPC topics in RSLinx.
edit: If by chance you are in the unfortunate situation that all of your tags in the PLC are different (eg, each tag suffixed with a 1 or 2) then maybe using the tag inport/export tool along with excel could streamline the process. You can still use the tag import/export tool even with a runtime only licence, just import the correct CSV for the tags just before running the spare.
We have an older laptop here at work that has RSView Studio on it that isn't used for anything. They only use Red Lion HMI's now. I was thinking...
1,520
what's the difference between Rsview ME and RSVIEW32 works and can'i migrate a RSVIEW ME project to FActoryTalk !!thnx....
1,576
For this particular client we have many RSView32 Runtime licenses and each one is local to the individual computers. We have one RSView32 Works...
2,475
I have the VB code: Private Sub NumericInput5_Change() Dim Logged_Message As String Set oPC = Me.FindElement(Me.ActiveElement.Name) Park_Veh...
1,334
Hi people thanks in advance for your replies. I have a process which takes 3 hours for the product to get from start to finish. If there is a...
3,746
