RSVIEW 4.0 User Accounts Problem
Steve Cav
Aug 2006
Clitheroe
71
I have in numerous RSView applications created login / logout pushbuttons and then prevented access to "Goto Configure" pushbutton via animation. This has worked well in version 3.2 in the past.
However, I now have an application which may or may not have originally been created in 3.2 but is currently being modified using version 4.0. Unfortunately when I implement the modification detailed above and attempt to login I get the message "Login of user 'XXX' failed. Insufficient access rights"
I have 2 accounts, the DEFAULT and another called ENGINEER. Both accounts have access to all screens. The ENGINEER account was created by: -
- Going into User Accounts
- Select RSView3.x Accounts tab
- Add the account with "Y" for all (A-P)
- Select RSView4.0 Accounts tab
- Select SETUP from toolbar and then select migrate 3.x user accounts
- this completes successfully
However, when running a test application or downloading to the Panelview 1500 I get the same error message when attempting to log in as ENGINEER.
Any ideas?
Steve
Hi Guys, Brand new here...! In RSView ME 8.00 and up, it is possible to create new users on the PVP terminal, by swiping an RFID card through a...
1,792
Hello to all the knowledgeable people inside the computer screen, my problem at the moment is like the title says, l can't open projects in...
1,332
Hiya. I've been a lurker here for years, but now I have a question for which I have no answer. I have an RSView ME application that is installed...
5,582
Is it possible to read the current logged in user from a Panelview Plus, like you do with global connections and display numbers etc. I have...
4,262
I'm trying to find a user manual for RSView Studio V4.0, anybody know where I can download one? All I can find is the FactoryView V5.0 User...
6,412
