RSView access to SLC-5/04 thru a Gateway
hhuong
Nov 2004
58
Is there a way to configure an Ethernet I/P direct driver in RSView 32 to "drill-down" thru a 1756-ENBT to a 1756-DHRIO and access a 5/04 CPU on DH+? What Data Source (Direct Driver, OPC Server or DDE Server) I should use in the RSView Node Editor and How? When I try Direct Driver, I get "Unrecognized DTSA Structure" msg. in the Node Configuration tab of RSView.
Thanks for the help...
herbert
Yes, and no. Use the regualar AB Ethernet driver to accomplish that. the 5/04 doesn't understand CIP communications, but will do the encapsulated protocol with the AB-ETH driver.
Note that you need RSLinx for this, not Linx Enterprise.
I try to use Direct Driver as my Data Source. When I try to set up Node Configuration Tab, I get "Unrecognized DTSA Structure" Message during specifying the station.
Yes, I am running RSLinx. Make a topic with 5/04? I assume that it is DDE/OPC Topic Configuration, right? If so, is that mean I can create an OPC or DDE Topic and use it while I use Direct Driver as my data source?
Use "Remote devices via Linx Gateway" driver. You should have no problem. In fact this is a common way to bridge from E-net to DH+.
Here is the path of my network.
PLC5/30 -> PLc5/30 -> SLC5/04 -> DHRIO ChA -> Backplane1 -> ENBT -> Switch ->Laptop
Would you use Direct Driver, OPC server or DDE server as Data Source for my current network in order to optimize the performance of RSView32?
I am really confused how to set up OPC server and DDE server in RSLinx. Any Help??
Hi All, I am trying to setup a new data log model in RSview 32 with storage as ODBC and assigning the microsoft access driver. I created a new...
4,104
Hi friends I have a change of integrating RSView32 HMI to read value from MS office access database. HMI running on RS link OEM Asst which is the...
1,752
I'm using RSView VBA to record the last parameter adjustments made for a given product in an MS Access data base. The Access table contains...
2,340
First let me post the reason. I need to have RSView interact with an external application tying the alarms to an external logging application...
11,400
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
308
