RSView and RSLogix5000
yesidh
Jan 2007
Bogota
Hi all,
I need to communicate a ControlLogix controller to a PanelView Plus CE, unfortunadly I don't have the hardware now, so I haven't be able to do a test on this.
My question is about accesing the program tags from RSView, or It can only see Controller tags??
Well, I thinking that the above it's not possible, so for you experts, can I read a UDT from RSView.
I appreciatte all your help on this topic.
Bye
YES, you can read both Controller Scope and Program Scope tags in RSView ME. You can read all subelements of User-Defined Data Type tags in RSView ME.
The Program Scope tags show up in the FactoryTalk tag browser as a sub-folder of their own, labeled "Program:MyProgramName".
Similarly, the UDT data type shows up as a folder in the tag browser, with each subelement showing in the Tag list on the right.
Be sure that you create a Shortcut in RSLinx Enterprise, even if it doesn't have a valid target, and associate an Offline File (*.ACD) with it. That will allow you to browse the tag database in the *.ACD file.
I have created a Compactlogix PLC program with RSLogix5000, and now want to export the tags to PanelView Plus program created with RSView Studio...
11,563
Hi Folks ! I want to show up 5 Array of 200 Reals in Excel. Normaly I make a direct connection from RSLinx with copy and paste. For example...
3,185
Well guys im looking for some ideas or help with a problem that im having. I am trying to monitor the communication between rsview and logix 5000...
4,854
Hello guys. I've finally begun using some ControlLogix stuff, moving up from SLC500, and there's a few roadbumps I'm having issues with: 1...
31
15,205
HELLO ! I am using RsView Studio-ME with Control Logix5k processor with Ethernet driver. I am trying to import the tags from RSLogix 5K program...
5,487
