RSView ME Accessing UDT in Clogix 5k
jimdi4
Aug 2004
108
Anyone know how to access the UDT tags in Clogic 5000? I am putting together a validation MMI for a Clogix 5000 application and it has many User Defined tags that I need to animate in RsView ME Studio 5.00.00 (CPR9).
I can see the online tags but not the UDT's...Any ideas?👨🏻‍🏫
That is a new one, have not seen that problem before. You should be able to see the UDTs. Sounds like you may need look for any patches related to the version you are using. I am currently on V5.1. See the attached picture.
Darren
I've seen that before,where sometimes even just created BOOLs and don't show up in the Online Tag Browser. Even doing a Refresh All Folders did not help. Had to reboot PC.
Warning be aware of communication performance see CLxPerf.htm on the RSlinx CD for lots more details
Like most systems the better the structure of the data in the PLC the faster the communications.
This may help from knowledge base article "36270 - RSView Machine Edition HMI/Direct Reference Tag Best Practices."
Offline tag browsing requires the RSLinx Enterprise Offline shortcut to be re-browsed
RSView ME caches the offline tags once
Any changes in the offline file will not be visible by simply “Refreshing All Folders”​
Dolt - curlyandshemp said online! this is offline - oh well
Hello everyone, this is my first time posting here, I have been going crazy trying to find an answer to this and thought maybe you guys could...
6,897
Hey guys. I´m kinda new in PLC world. I say that cause I know some concepts but don´t know how to use them with the tools i need(RSLinx...
2,942
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
300
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
258
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
811
