RSView ME Report Printing, plz help
westec
Jun 2006
Manitoba
Good Day,
I am currently creating a project in RS View ME, to be used on a Windows 2000 computer in runtime. I need to print a report of recipe ingredient quantities from the project. Essentially, I just need to print up information in some memory bits.
I cannot find any specific supporting documentation on how I achieve this.
I have found some information on Rockwell's online knowledgebase, but I am not sure it applies to RSView ME.
http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/0/546AC045992A920E85256AFB00702006?OpenDocument
It refers to a print only object (P.O.O.) that I need to use, however, I cannot find such an object existing in the software nor can I find the ability to "enable printing" in RSViewME, which it refers too.
If anyone has any experience in this matter please let me know. I would deeply value any information or assistance. If you would like you can e-mail me directly at [email protected]
Thank you very much,
Andrew
P.O.O do not exist in the PV+/RSView machine Edition platform.
My guess is you will need to build a screen that shows the data you are interested in and add a Print Display button to that screen.
jjsohio
Thank you for the reply. I have attemped exactly that, however the printer that I am using is a point of sale unit and does not support graphic printing very well at all. It is a Epson TM-U295 and is essentually used for recipes and POS systems. I am trying to get help from their development area, but with limited success.
I guess I am looking for an ActiveX control or a VB script. Something that would help with the printing or reporting. Is anyone aware of something like that?
Andrew
FYI for anyone interested in this topic, I have contacted Rockwell's technical support line.
According to Rockwell they cannot print any sort of reporting at all from their RSViewME runtime software aside from Alarm logs/history and to do a print screen. You cannot print reports or anything else for that matter natively from the runtime environment.
I am going to have to obtain a different printer that has better support for graphics to do a print screen.
An ActiveX control or some other 3rd party software might be able too, however none seem to exist at the moment (that I or Rockwell are aware of).
I'm shocked as it seems I might be the first one to even attempt this (or at least get help with it). Just my luck...
I wish to make report in the form of excell of PLC tag by continue each;every 5 minute in course of, without having to depress any, become so...
1,995
hi all, i'm using rsview me scada which installed at pc not panel view so i tray to creat historical trend by rsview me but this fail because...
2,882
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
298
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
256
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
811
