RSVIEW ME Restore Error
quasar273
Feb 2007
Lahore
I am facing a problem in restoring RSVIEW ME application. While restoring an application, the application manager issues an error which is enclosed. In-fact, I can not even backup an existing sample application. Similar message appears when I try to backup and existing application.
The error message issued is : "Unable to restore the applicatin 'application name' from 'application path'. Pleae check that: there is sufficient diskspace, the application is not open elsewhere, the destination application does not already exist".
I have installed RSVIEW studio release 4. I have also tried installing the various patches, but they don’t seem to be of any help either.
Can anyone through some light on this?
Clear skies
Omer
Make sure that you have also installed RSLinx Enterprise software on the machine you are using. There was another post on this board where a person was having the same problem, because RSLinx Enterprise was not installed.
Even if you are not using it for communication, RSView ME likes to see that RSLinx Enterprise is present.
Rick
thanks also from me, I had the same issue, somehow managed to loose RSLinx Enterprise.
You'd think that the error message would mention the missing component
My hard drive failed and I had to replace it and thus I have lost the RSView 4 application that's in my PVP1000. I can get the runtime file, but...
2,286
Recently had a catastrophic OS failure on my laptop. Fortunately, I had just replaced (about a month, or so, ago) the HD (mirrored the smaller...
4,224
I have just wasted 3 hours of development time. I created my MER file from the APA working file, and then for some reason, deleted the main...
5,054
I got a PanelView Plus 1000 application that is working fine from as far as communication my laptop and RSView Studio ME 3.2. The problem I am...
5,929
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
325
